Hi Glenn,
If you haven't ever Flashed User Data to KFLOP then every power cycle should reset KFLOP to its default state. That is why we do not recommend ever Flashing User Data.
If you have Flashed User Data using the Config/Flash screen then you can restore power up defaults by re-Flashing the KFLOP Firmware using the the "New Version" button on the Config/Flash Screen.
If a bad program or configuration has been flashed such that KFLOP will not even boot then you can use the Flash Recovery Option on the Config/Flash Screen. With KFLOP power off, startup KMotion.exe, Push the Recovery Button, Follow the Screen prompts.
